UDIM implementation overhaul
Lots of things that could be done to improve UDIM workflow. Here's a few things.
-better shader for UDIM texture loading. Selecting ":xxxx_basecolor.1001.tga" will load all tiles. No more typing "<UDIM>".
No more multitile messy set ups. Simple, simple simple.
- improved display in the Unwrap. Snapping to UDIM tile maybe. just better tools.
- Better display in the viewport.
Just improve it please.
1 Comment
EricsUsername
PLEASE ADD:
Expose RENDER UV TEMPLATE TARGETS to Maxscript.
(Unwrap_UVW modifier -> UV Editor Window -> Tools Menu -> Render UV Template (dialog then pops into view))
The Render UV Template from Unwrap_UVW has  a setting for which UV templates to render. This is set to default and is only changeable via manually drilling to the dialog window. Tiresome/user-energy-expensive.. ESPECIALLY for batching since batching UDIM UV TEMPLATES with MXS isn't possible at this time.
• Choices provided in the dialog window:  #( default , All Tiles, <U1V1>, <U2V1>, <etc>).
