Transfer Editable Poly Edge Selection to UVW Modifier Edge Selection
Show only
Search instead for
Hi, It would be nice if there´s a way to transfer editablePoly Edge Selection to UVWModifier Edge Selection just the same way as polygon selections are transfered.
Are you talking about how you can select some polys, stay in Polygon Sub-Object mode, add an Unwrap UVW Modifier and the modifier only uses the selected faces?
If so, you can already accomplish this via this method: Select your Edges, then CTRL+Click the Polygon sub-object icon in the modifer tab > Selection Rollout (or simply right-click the view port and click Convert to Face in the quad menu). This will change the face selection to those needed for the action; then add an Unwrap UVW Modifier.
Thanks for your reply, but what I need is given a selection of edges at the Editable Poly level, to have the same edges selected at the Unwrap Modifier level.
I mean, I have a selection of edges in the Polygon Sub-Object mode and I need to select the exact same edges in the Unwrap UVW Modifier.
Thank you for clarifying. So what you mean is how, when applying the Unwrap UVW modifier, it defaults to Polygon Sub-Object mode with whatever polygons were selected in the editable poly are pre-selected? You would like the edges to default to being the same selection from the object when you switch to edge mode in the modifier?
For example: I have a number of selected edges in my mesh that I need to break in the UVW Unwrap Modifier and I can't just get that selection automatically in my UVW modifier.
When I delete the Edit Poly modifier the UVW Unwrap Modifier seems to have lost the unwrapping I did for the mesh with edges splitted. But I copied that UVW Modifier and then pasted over and it works.
It allows you to transfer(convert) edge selection from editable poly object to edge selection in uvw modifier(uv edges) or to transfer(convert) edges selected in Unwrap UVW modifier(uv edges) to editable poly edges.
