Show only
Search instead for
yes, a symmetry mode has its role and its not a replacement for the symmetry modifier. Its onl a matter of time until Blender will have it since as of now its kinda forgotten because it remained half assed implemented and support only transformations. Maya team has done a really good job on this.
I was just going to ask for something like this, I think it is a MUST for modelling. Usually when I have a model that I need to keep the vertex numbers intact, I cannot use symmetry because it is going to make a mess of it, so usually I have to use the Symmetry tools from the Ribbon but those doesn't give you instant update, you have to do your transformations in the EditPoly for example and then press To right or To left to get the result.
you might want to change the title into Symmetry Mode support for Edit Poly Tools and and embed the picture into the original post instead of attaching the file. This is a big feature.
