I would like to be able to straighten out UV shells without destroying the already flatten out UV.
For example, I use the quick peel mode a lot to layout my UV's, and I like the overall result from the quick peel. It does a good job of unwrapping my objects; however, it almost always leaves the shell skewed and rotated at a weird angle. See attached image called Peel. If I hit the straighten selection button it tries to calculate everything again and I get an awful result, see image called Straighten. All I want is for the overall shell to straighten, not the UVs inside the shell. So right now, I have to manually rotate them all so I can get the desired effect. See image called Desired_Results. Usually, I don't mind as much if they are rotated, but when I need to texture brick or anything with a pattern, I need them to be as straight as possible.
I don't think there is anything like this at the movement, but it would be really beneficial to my workflow to have something that makes this process faster and easier. I know Unfold 3D has this per Island packing that allows you to straighten the shells without distorting the layout. Is there any way something like this can be implemented?
Dani
