Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Soft Selection shortcuts
Soft Selection is strongly used when modeling,
but it lacks of keyboard shortcuts.
Users should have to edit this after installing, it should have keyboard shortcuts assigned by default.
There is already a great tool to edit the soft selection setting (falloff, pinch, bubble) directly in viewport already: Edit soft selection
and also a command to turn it on and off: soft selection toggle
Assign by default: B and SHIFT+B to make it consistent
4 Comments
brentscannell
Hi @Xerges
We're doing a bit of research around hotkeys right now, and one of the subjects that keeps coming up is a revisit of the defaults. I'll move this over to "under review" status. Are you part of our beta program yet?
joeaf9321
I think that we'll be pretty useful that we could have som kind of preview of how the transformation will affect the subojects like the Soft Selection tool of Blender, where you can dynamically change the radius or fallof curve of the tool while making the transformation, because in Max is process of trial and error sometimes. also it will be good to add some presets for the Fallof Curves and upgrade the Fallof Curve Editor to be possible to handle directly ckicking and dragging the curve.
brentscannell
joeaf9321
@brentscannellwhat was implemented, the shorcuts part?
