コミュニティ
キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
このページは利便性のため、翻訳システムによって自動的に翻訳されています。正式な翻訳として提供されるものではないため、不正確な翻訳が含まれる場合があることをご承知おきくださいオートデスクは、機械翻訳システムによって翻訳された情報の正確性、信頼性、完全性について、明示または黙示の別を問わず、一切の保証を行いません。また、お客様が機械翻訳システムを信頼することで生じた損害または損失については、いかなる責任も負わないものとします。 翻訳
Soft blending between boolean meshes like Modo Meshfusion
Modo Meshfusion can create topology based chamfers between boolean polygonal meshes. The current boolean implementations in 3ds Max are only useful as either a starting point for modeling in combination with Quadify or Quad Chamfer To simulate rounding. However these last options only work on quite simple and mostly flat meshes.
The main code of an Autodesk alternative to Modo's MeshFusion could also re-used in for example Maya. This is the main advantage of Modo over 3dsmax and Maya at the moment (for me).
66件のコメント
much needed
s1dK
Someone made an awesome plugin for Maya as you can see here - https://vimeo.com/204707688
Can we have something like this implemented in 3ds max? It`s just perfect for modeling and to quickly create nice shapes with chamfers.
Thanks.
タグ(5)
markus
That looks very similar to meshfusion in Modo! I would love to see this functionality in 3dsmax. 3dsamx 2017 came a bit closer with the new boolean tools, but the fillets/chamfer functionality is still missing!
s1dK
Yeah it is similar to MF in Modo but this one doesn`t require to have many amounts of subdivisions like mesh fusion.
reallukx
especially we need strip feature with booleans : https://www.youtube.com/watch?v=3UAWiFEliO4
OccultMonk
It can be implemented in 3Dsamx (it's not even that complex)! It has already been done for Maya:
http://www.hard-mesh.com/http://www.hard-mesh.com/
The code should:
  1. Use the Existing Booleans features of 3dsmax (for example the new Bool 3)
  2. Cut a strip where the meshes intersect of a variable width in both meshes.
  3. Create a 'chamfer' strip between the parts of the geometry (this strip should have an adjustable 'loop count/tension/chamfer hardness. (And average of topology of both sides)
  4. Connect the gaps on both sides of the new strip topology with topology that connects the meshes with the strip. (Maybe an adapted algorithm of the Quadify modifier could work).
Swordslayer
There's an existing script that aims to make the chamfering of boolean intersections / shapemerged shapes on editable poly easier. But I wouldn't say it's not that complex.
Kelly_Michels
変更されたステータス: Under Review
Ehsan.Sarahian
We use MODO only for MeshFusion if MAX has this we don't use MODO in our pipeline ...
michael_spaw
yep its on the designers radar.
-Michael
Kelly_Michels
変更されたステータス: Future Consideration
適用対象外
integrating an elegant live boolean system and intersection control per operator is 100% necessary for the future.
Currently, I'm bouncing between scripts and using zbrush's extremely powerful live booleans, but it looks like only modo is offering fast, clean, non-destructive workflows for this. Hardmesh seems to be a great alternative for maya users, but for those of us working in studios, licensing can become an issue, so I'll add my voice to the choir calling for integration directly into autodesk products. 🙂
Br0ken1334
Blender already have similiar script "Bevel after Boolean".
https://blenderartists.org/forum/showthread.php?434699-Bevel-after-Boolean
So that workflow available for almost all major 3d apps (Modo, Maya, Blender), except 3ds Max. 😕
Br0ken1334
markus
BTW, when you’re at it improve/fix the current boolean as well. Right now (max 2017 at least) when you go above a certain polygon count it seems to convert quads to triangles and starts to fail when polygon count is high which is critical since you can’t subdivide after performing booleans since topology no longer works for subs obviously.
Br0ken1334
Just look at this: https://youtu.be/TXRK0SYpk74
metalman123456123
Please Add this feature its 2019 now and we are still waiting for a feature that was promised years ago.
what kind of geometry that program produce ?
markus
Not sure what you mean by this? Fusion 360 is a separate cad modeling software that use Nurbs and T-splines.
Maybe you are thinking about a boolean operation like"mesh fusion" in Modo which creates a boolean mesh-strip fillet around the intersecting edges? I think there is a separate request for this somewhere...
michael_spaw
Fusion360 does all of its boolean operations as a solid representation not as polys. What specifically are you hoping would be the feature set or the workflow/results?
-Michael
Michael Spaw
3ds Max, Product Owner/Designer
Media and Entertainment Division
アイデアを提出
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
