Seriously. Do anything to make this better.
Copy Paste from one Max window to another? Instead of bogus ass merge.
How about rotate with reference like one can do in CAD?
Units scaling? Like, say I import a thing and some doofus made it in centimeters, and I use inches, let me scale it properly, instead of having to goof around with your dumb and bad UI and make up some "TRICK" to scale it right.
Better importing from CAD.
I'll say it again: Better importing from CAD.
BETTER IMPORTING FROM CAD
BETTER IMPORTING FROM CAD!
Oh, and I think better importing from CAD would be cool. Like, I don't like how I import a DWG and when I move it, it explodes and things move in all different directions. I also don't like how Layers and Blocks import and are sometimes stuck and I can't delete them.
You're the same company. Implement some better importing from CAD.
Take a page from Adobe. You can literally copy and paste stuff from any of their programs to any other of their programs, and it imports as usable things that don't fly apart, and don't have hidden, invincible things.
Make the modify panel make more sense. Make it hierarchical instead of this inverse, pretend, house of card, stacking thing that you have going on.
Render tokens. I want to be able to say, "Hey. Max. I want to use this filename structure, but just add a number to the end of each render for these 5 scenes." Instead of having to type out EACH AND EVERY PATH AND FILENAME! It's so heavy handed.
Like, really. It's be cool if the rep showed up at work and didn't brag about Arnold that no one is using and actually showed some fixes that meant a ****.
