Shell Modifier Taper
Please add Taper/Flare options to the Shell modifier so I choose to either taper the inner or outer faces, depending on the effect I want.
7 Comments
michael_spaw
would love to see examples of what you are shooting for.
-Michael
Michael Spaw
3ds Max, Product Owner/Designer
Media and Entertainment Division
Hey Michael,
Thanks for your time and interest. I work in the games industry and this request essentially comes down to how many of us approach hard surface modeling these days. I'll start with a loose Dynamesh sketch in ZBrush to dial in proportions and primary shapes, then use Max's Graphite retopo tools to make clean geometry for edge creasing and OpenSubDiv. This will be the final high poly mesh that will eventually get baked once the realtime model is done later in the pipeline. What I typically want to do, since I'm doing retopo on the outer surface of the dynamesh, is extrude my panel thickness INWARD rather than outward. Face extrude and bevel functions alone don't work well because they don't provide an option to cap the area you extruded - that side is left open, which is undesirable. So...Shell modifier to the rescue since it caps both sides and gives you the option to extrude either outward or inward, or both. This is great, however, I often also want to add a taper/flare/bevel (whatever you want to call it) to the extrusion so that I'm not baking 90-degree angles and to add more visual interest to the final result.
My current work around is to make a copy of my flat retopo panel, flip the faces of the copy, bevel the copy, attach it to the original, then weld it all together. It gives the desired results but it's an awfully step-heavy process for something I do a lot of.
So my suggestions for all of this is simply to add a taper function to the shell modifier so that you can extend the panel either inward or outward, then taper the result.
If this still doesn't make sense let me know and I'll try to clarify further. Thanks again!
michael_spaw
Nice explanation. If you are willing please post a image or two. It will help others to see what you are asking for and make sure I can better explain it to the Developers if we decide to act on it.
Thanks again.
Hopefully you're able to see the image I included with my previous post. Here is an additional image, just showing how I imagine it being implemented. If you need a specific image that would help better clarify, let me know and I'll be happy to do that. Thanks!
michael_spaw
Looks great! Thanks for the details.
-Michael
Kelly_Michels
Pls come on beta and push for this! Shell is one of a hell used and useful modifier. Maya doesn't even have it and about and year or so it didn't have a reliable way of adding thickness besides  extruding, negative scaling etc(destructive or not).
It has so much potential with a minimal of treatment. Cmon Autodesk!
