Set and Lock Command Panel Column Width
Hi!
I really would like if I could set the column width of the command panel columns by a slider and then lock it. When its locked, the currently adaptive and dynamic with adjustment behavior on drag, will be disabled. So when I drag the columns, the width keeps static and won't change anymore.
I made a little animated mockup, please take a look (especially on the lower right corner).
https://i.imgur.com/1fkJT4D.mp4
Thank you and greetings!
1 Comment
definitely needed
