Selection Element Buttons
The Sub Object selection icons in the Command Panel currently use Red, which does not read well against the grey background- and having a bright yellow highlight- it's always been a bit of an eyestrain.  I suggest replacing these with the light grey, black lined buttons from the Ribbon equivalent and making the two consistent.
See attached picture of how purdy it is.  🙂
2 Comments
Swordslayer
Did you install a custom icon set? Because subobject icons in 2017 look like this by default (an you can customize the highlight color, too):
brentscannell
Status changed to: Archived
Hi @Anonymous
I'm going to archive this because what you posted seems close to what ships with 3ds Max already, as @Swordslayer pointed out.
