Scene Optimization Manager
There are a multitude of plugins, scripts, and general workflow methodologies, which help to optimize scenes, however, there is no native centralized tool to accomplish this. Therefore, I recommend the creation of a "Scene Optimization Management" panel (SOM), which utilizes a dashboard to help a user identify potential issues within a scene and provide a multitude of options for the user to optimize their scene to meet particular production goals.
This management panel should contain the following:
  1. Dashboard - This interface would function on several levels; provide a general overview of the scene, display general statistics such as polygon counts, object numbers, xrefs, materials, etc., display potential issues based on stock and user generated criteria (drop menu). This would also display stats based on specific object, group or layer selections.
  2. Asset Management Tool – This would be a significant overhaul of the current tool. This should allow remapping, searching, copying of assets from one location to another, file format change (JPG to TGA for instance), file scaling (scale to binary multiples or scale from 2048 to 512 for instance), gamma adjustments, support for all assets other than just images (Proxies, Xrefs, Containers, etc.), sorting by columns.
  3. Wizard based optimization – This would be a wizard oriented tool which walks the user through various questions to help optimize a scene based on user defined criteria. This wizard tool could also create “batch presets”, which can be saved by the user for later use.
  4. Integrate the Scene Converter functionality
  5. Maxscript/Python/.Net/MCG integration – This would allow for users to create their own custom tools to meet specific production need.
  6. Render to texture integration – This should support both bitmap and procedural rendering
  7. Batch Processing integrated into 3ds max command or core – This functionality would allow a user to batch process scenes without opening 3ds max. Perhaps this could be integrated into the 3ds max Asset Library Tool.
2 Comments
mark_kauffman
A few other ideas:
8.  3rd Party Plugin identification - This tool would allow the user to identify assets in a 3ds max scene which have 3rd party plugin dependencies. This would help the user to determine what assets might not transfer to another system such as a render farm or a client or collaborator's system. In addition, it would help to identify assets in a scene which are missing a 3rd party plugin and provide options for the user to take corrective action.
9.  Modifier collapse - This feature would allow the user to identify all the scene assets which require modifiers which might be collapsed for greater scene efficiency. This feature would also help the user to identify how the modifiers are used to better determine whether collapsing would cause problems, such as the use of a morpher or skin modifier. You could also use this feature to prepare a scene for transfer to an external location such as a render farm, client computer or collaborators system.
10. Game/Real-time Asset Prep - This tool would help a user identify optimizations for export to a real-time or gaming environment.
Kelly_Michels
