Yes, more than 1000 clones might seem like a lot for the Array modifier, but I have encountered situations where I need more than 1000 clones.
This hard coded limit of 1000 clones feels unnecessary and should be removed, or at least significantly increased.
Edit:
It seems like this clone limit applies to the modes Total Dimension and Relative Offset, which means using Fill mode as suggested by a user can provide a workaround since it allows for generating more than 1000 clones. However, in these modes the number of clones are determined by other factors than clone count, so setting a specific amount of clones can be tricky and tedious. It would be better if the other two modes had the clone limit extended or removed completely.
Edit2:
I suggest that rather than having hard coded limits to spinners the Array modifier should have a Max Clones parameter similar to the Normalize Spline modifier has a Max Knots parameter that the user can change depending on needs. With the new "set default value" feature the user can specify any preferred default value, or just leave it to the factory default if the default value is enough for all situations.
