Show only
Search instead for
Need to have the ability to export a low intelligence file for use in SolidWORKS or Inventor. STL format would work well however you can't do anything such as move, rotate, place parts in a assembly with it once imported.
Hi @Anonymous and thanks for the suggestion. My only concern is that we wouldn't be able to add functionality to an STL export. Even if we did, the software importing it would need to be able to read that. Can you export out various groups individually and should be able to do bring them in as separate parts.
Looking at alternatives though, if not in STL, what other formats would be good?
Thanks for sharing that. Given we probably can't do them all, which would be the best to start with? In this one you mention STEP. Would probably be better to merge these two ideas if that's the best place to start.
