Navisworks Simulate/Manage interoperability
A lot of work has gone into making 3DSMAX more compatible with other design applications - Inventor and Revit being notable examples.  This allows using the appropriate software for design work, and using 3DSMAX as a "front end" for high-end visualization work rather than attempting a full-blown rendering/animation interface inside each product.  I'd like to see this effort continued with the Navisworks Simulate/Manage products for similar purposes.  One of the end goals would be to use Navisworks as a "pre-vis" package for large projects, such as industrial facilities or building complexes, before committing to the expense of a high-end 3DSMAX output.
There's a number of highly useful features found in Navisworks which are not present in other programs; for the purposes of this Idea the most important are federated models and the Timeliner feature.
Navisworks products allow for a wide range of 3D formats to be viewed together, without needing the originating software, to create an overall "federated" model with properties appropriate to the objects for selection and filtering.  Work has been done to reference Navisworks content back into other programs (Revit, AutoCAD/verticals, ReCap).  It would be useful to apply this to streamline working with Navisworks content in 3DSMAX.  There is something of a round-about method of exporting to FBX, then importing into 3DSMAX, but it has limitations.
The Navisworks Timeliner allows for a Gantt chart (from Microsoft Project, or manually created) to control some basic appearances based on a project schedule.  In addition to reading the model content, being able to read the Timeliner information from a Navisworks file would be useful.  One of the reasons for doing this and not reading a project schedule directly in 3DSMAX, is quickly apply scheduling information based on object properties.
5 Comments
SolidSupportCAD
As It is currently supported by Navisworks, the ability to simulate any tip of project of scenario base on a Gantt chart, with an import where the obects can follow a timeline and automatically animated using opacity, slice modifier, colour change, etc.
Would be an amazing implementation and would get max a valuable product across many mani different industries, including project management, construction and engineering, planning, motion graphics, etc..
brentscannell
Hi @SolidSupportCAD
Just to make sure I follow this idea 100%, would it be the feature shown in this video?
https://www.youtube.com/watch?v=TOdYUHBOAWY
SolidSupportCAD
Yes Brent, I do use Navisworks quite often, but clients want every time more and more the quality of max, and there's no tool to translate the animations made in Navisworks to Max in a seamless way.
This would join the world of simulation and animation together, making the workflow of Revit-Max, not only a powerful visualization tool but also a simulation tool too.
dgorsman
@brentscannell, @SolidSupportCAD - I'd *love* to see a more streamlined method for moving content from Navisworks to 3DSMAX, not just time-based simulations from Timeliner.  Naviworks animation makes a good pre-vis tool for planning detailed work on larger facilities while they're still in the design stage.  And it's already converted to surfaces internally.  But to get to 3DSMAX we need to go back to the original model content (which may be from a host of different sources), convert, and re-coordinate them.
SolidSupportCAD
You're right about the different sources, we use skp, fbx, max an rvt files within the scene
The @Anonymous@ has to be implemented in MAX.
Like an extension that applies modifiers based on a csv this would be a huge breaktrough in BIM and simulation in MAX.
There's NOTHING right now on the ,arket that offers the best of modelling software and simulation software at the moment.
