multiple object import
i have been working on an idea for a project, and have encountered an issue that has lead to an idea. when importing multiple .obj meshes, there is no option to import them either as a single group, or even as a group of separate objects in one fell swoop. this would be useful when dealing with multiple objects that are saved as separate files, and need to be imported as one file without them being saved as a single file. (all that needless messing about with detaching is also annoying. if max could import a set of separate objects (whether as .obj or even as .max), that would make life easier. photoshop allows this by treating each as a separate file to be loaded indiviually. max could use a similar technique. so long as there is enough memory to handle this, it really shouldn't be a problem.
