MAXScript needs more access to the Keyboard
Right now the MAXScript access to keyboard is limited to just modifier keys:
  • keyboard.shiftPressed
  • keyboard.controlPressed
  • keyboard.altPressed
  • keyboard.escPressed
I propose that there is also a new readonly parameter: keyboard.otherKeyPressed
This parameter will return true if any key other than SHIFT, CONTROL, ALT and ESC is pressed.
Why would you want this?
I built a collection of MacroScripts that I wanted to include a default Alternate Action that would, instead of running the action, take the user to a documentation URL for the action. So I arbitrarily chose the SHIFT key. This way, if the user SHIFT-CLICKS the macroscript in the menu bar, the user will go to the documentation. There is one problem with this: if the user assigns a keyboard shortcut that uses SHIFT, the function won't run as the user expects.
If this new parameter is added, you can do something like this in a MacroScript without worrying about colliding with keyboard shortcuts (which require more than a modifier key):
if (keyboard.shiftPressed AND NOT keyboard.otherKeyPressed) then (
--do alternate action
) else (
--do primary function
3 Comments
Swordslayer
As a temporary solution, this should work for you:
	local kbd = dotNetClass "System.Windows.Input.Keyboard"
	local key = dotNetClass "System.Windows.Input.Key"
	local keys = getPropNames key
	local otherKeyPressed = false
	for k in keys where k != #None and k != #DeadCharProcessed and k != #LineFeed and k != #System and k != #LeftShift and k != #RightShift
		while not otherKeyPressed do otherKeyPressed = kbd.IsKeyDown (getProperty key k)
	otherKeyPressed
Kelly_Michels
lightcube
@Swordslayer Thanks for the info. I tested this and found it to suit my current needs inside a MacroScript. For performance purposes (not looping over the keys array in functions that have a high callback rate), it would still be beneficial to add the otherKeyPressed property.
