Thanks for taking a look at my idea!
I work in Arch Viz, when i create elevations i need to use an orthographic camera.
It seems that the new physical camera does not have this option, so i have to use a standart target camera.
I use Vray so use the Vray exposure setting in the environment to set exposure.
would be nice to have an orthographic option!
My second idea, is to allow the camera to change the aspect ratio when you select it. So you would set the ratio in the camera, and potentially just set the largest pixel dimension.
once upon a time, i used Render Pass Manager, this was really helpful.
We just upgraded to 2017, from 2014, though I don't think we have service packs installed yet.
I noticed two bugs with the camera:
While in walkthrough mode, if i type something in an email, or in a web browser, i return to max to find that my camera has walked around! yes, i should probably not be in walkthrough, or footstep mode. i know it used to happen within max, but not while typing in another package!
The second, when i framed up a still shot, making use of vertical shift, the viewport hasn't updated,
