Material Override for Arnold and ART
Material overriding is not presented in main interface for Arnold and ART. For Arnold known solution is  http://veda3d.com/override-material-for-arnold/ , but I think that this option must be present on main interface.
2 Comments
stephan_reischer
I would like to have that in good old Scanline as well. Sure, you could use Scenestates to get this effect, but you lose the connecten between MatEditor and Scene (if you want to modify a material you must reload in Mateditor -be aware of the Triangles of the swatch ;-).No better to have this option for every built-in renderengine.
Just my 2Cents,
Stephan
bruno.landry
Status changed to: Gathering Support
Hi, in the Render Settings + Diagnostics tab, there's a Shader Overrides function:
Shader Override
Global shader override which allows you to override the shader for all objects in the scene.
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Feature+Overrides
is this what you are looking for?
