In general, work with the library of materials is extremely inconvenient.
To just open it I need to press a 4 buttions and after i need close (or there will accumulate a lot of junk)
1 Get Material
2 Map brouser options
3 Open material library
4. Find file (always the default path).
Аfter i need Close Material Library buttons:
5. Get Material
6 Chose library
7 right click
8 close library
If i need to import several materials, the procedure must be repeated for each library.
I think it would be better that i can drag and drop the materials libraries files directly into the max and that they immediately open in a separate window like the standard editor material.
