Master/mass edit maxfiles
Problem: You have several Max files that are supposed to share attributes, but you don't want to do xref's for various reasons, but you still want to edit several scene files at the same time. For example lets say the environment or render stats needed to be changed.
Solution would be something like this: Open up a scene file. record via state sets your changes. Select the scene files you would want to change, with an option to make new as to not over write the old, and then publish those changes to the new Max files.
2 Comments
electrotoast_old
Archiving this based on the lack of community support and that we don't plan on working on this in the near future. Note that Archive does not mean delete. If at a later time we do decide to work on this, we can change its status at that point.
electrotoast_old
Status changed to: Archived
