Improve Color Picker...
Look at Corona Color Picker to see how you could improve standard max color picker. What I wish the most is:
1) Float 0-1 numbers
2) Hex color code
3) Kelvin Temperature
To me those are the most needed things, but if you want to add more I have nothing against it... 🙂
-Eugenio
16 Comments
Tupaia
+1 !!
Makes perfect sense to have float values for the colors!
8 bit (0-255) per channel is CG-stoneage.
Percent values would also be nice.
It should be possible to switch between these scales, of course.
For me will be good combine coolpicker (use it 10+ years) and corona picker (temperature and hex)
I personally would also like to see support for color swatch sets, like in photoshop - makes it easy to just click a swatch instead of fiddling and tweaking a dozen sliders all the time.  Also like photoshop, make them a loadable/saveable asset.
electrotoast_old
Maya has a better color picker. They should just share the same. Today most of tools are working in PBR and them using 0-1, in Maya you can choose the type of picker you want (values-wise). And this is much better for making tools that work the same on more than one app, or translating shaders from Maya<>Max.
In many software nowadays it is common practice to be able to set the desired color by pasting in its hex code. My request would be to add this functionality to 3ds Max's Color Selector as well. It is a small workflow improvement that would make Max more coherent in this regard with other software, say Adobe Photoshop and Unity. Pasting/typing in three RGB numbers is three times slower than just pasting in one hex code. Cheers!
Tags (5)
StephenMF
I voted yes.
I just want to mention that Corona renderer has this feature. And a temperature slider.
Small help, but now you know.
Stephen
There is a classic max plugin called Cool Picker that expands the default colour picker, but it does not have a hex field, nor colour temperature. I think the default colour picker needs to be updated in this regard. Relying on plugins is always a bit risky.
pastorpastor
I always loved 3dsmax color picker for his ability to pick outside of 3dsmax window, I mean you can pick anywhere on your desk, it still working. With photoshop for instance you can only pick inside photoshop document.
But there is an issue : when you are using multi screen configuration, and your main screen is, for instance, a 4K monitor with a 125% DPI window scaling applied, if the other monitors are set @100% the color picker is not working anymore on those screens , it pick somewhere else, the coordonates where it pick seems slided somewhere else.
something like Adobe or Affinity products have some crazy cool color pickers.
Cinema 4d has gone pretty crazy with it.
I wish the Op would have posted some design suggestions as well.
markus
I think this should be implemented soon! How difficult could it be? It would be low hanging fruit for the 3dsmax team to get this minor quality of life improvement into Max, right!?
markus
Hmm, I just became aware of the Corona improved color picker! It kind of makes this request redundant. I have Corona installed because it allows me to convert Corona scenes to V-ray even without a license for rendering with Corona! But remember to get your vaccine before you install it! 🤒
dgiffordTUVH2
Community Visitor
I miss my LW color picker.  Has color schemes, rgb, hsv, temp, hex, pick from image, pick from screen, a library of shades with import/export, palette customization, float, etc.
a modern UI design should also be considered not only added extra options.  Same as those Curve graph controls (Edit Curve) UI. These too ass soon they are implemented will give Max a totally diff feel because they are everywhere
jon79info
Don't mind the features, in 2022 it's still broken since forever.. if you... click on it in wrong manner
(this whiteness .. )
2022-02-01 19_52_46-R__PRACA_21 Bartek Boratyn_13 osiedle sobotka_MAX_18.max - Autodesk 3ds Max 2021.jpg
This is one of my favorite bugs. this superb effect happens if while dragging the slider, machine starts 'thinking' or saving. The slider visually runs out of range (outside of the whole box...) Once it happens, If I don't close it immeditately (cancel) max will crash-disappear.
