Fire and Smoke
Fire and Smoke
We still need fire and smoke solution !!!
It may not be the most advanced solution, but it must be EASY to use and FAST. This should be the main advantage for 3ds Max. Even visualizers sometimes need these things.
- The solution must be able to work in conjunction with the particle system.
- The result should be recorded in vdb format.
1 Comment
tsyba
If you don't have the development resources, just buy the old version of FumeFX.
