We are currently migrating data within this board to improve the community. During this process, posting, replying, editing and other features are temporarily disabled. We sincerely apologize for any inconvenience caused and appreciate your understanding. Thank you for your patience and support.
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Extrude Modifier - Choose Direction for Extrusion
[entry has been edited with refined ideas since initial post]
The Extrude Modifier is useful, but there is one annoying aspect of it that needs updating.
Currently the modifier will only extrude according to the original Z axis of the object. This means rotating the pivot only will not work to change direction, instead the user is forced to perform a Reset Xform on a rotated object when the intended extrusion direction is facing along the world Z axis, and after the reset rotate the object back to how it should be rotated.
Completely annoying and unnecessary procedure.
  • The modifier needs at least an option to pick which axis to extrude along, and if these axes are based on a modifier gizmo they become independent of the object transform.
  • Lock gizmo to external object to achieve "world space" type behavior (similar to how Slice modifier can lock gizmo to another scene object).
  • A second modifier gizmo can act as a target, where extrusion direction and length can be obtained from.
  • Automatically set extrusion length to the distance between gizmo/target could speed up modelling process quite a lot since eyeballing extrusion distance will no longer be necessary. This could also be utilized by custom scripts to produce modelling workflows.
  • It could also be potentially useful to use two independent objects to obtain direction and extrusion length.
Left: Extrusion Axis facing the wrong way. Right: Extrusion axis facing the right way.Left: Extrusion Axis facing the wrong way. Right: Extrusion axis facing the right way.
2 Comments
hwoRX6FJ
A very necessary function. I have wanted to propose this idea myself for a long time, but since the developers do not pay attention to the proposed ideas at all, I am already tired of offering anything.
bump!
