Hello everyone,
I have a few ideas, which would be nice if they could be implemented in the future versions of 3ds Max.
A visualizer working in a architecture studio sometimes has to refresh the Revit model 3 times a day, working along with the architects in the design process.
Link Revit function provides a really good base for this workflow, however it would be nice to add a few more features to it.
- Reload From file: Sometimes if a new Revit file is saved (maybe the plan has reached a new stage, and a new file is saved), you don't have the option to change the linked file's path, you can only reload it from the same file. (By detaching, and relinking the file you can lose important settings (materials, layer assignment, etc.).
- Sorting of imported elements: I almost exclusively use Do Not Combine Entities option, because it's much easier to modify the model like this, which happens a lot when you are in the middle of a design stage. But like this, the model has a lot of objects, which are put into the same Layer. It would be nice, if you could predefine some importing options, for example sorting the objects by category into separate layers.
Gabor
