There's some existing sticky keys functionality within editable poly where bolded actions support "temporary override" - for example tapping Alt+X toggles Edge Constraint permanently, while holding Alt+X switches to it only for the duration while the keys are held and when released, it returns to whatever was active before. It would be great if this could be extended to be available for all the toggleable action items (so it would also cover custom macroscripts with isChecked handler) so that you could do for example temporary selection lock or temporary snap only while the shortcut combo is being actively pressed.
