Drag & drop image into plane
Can you add this simple functionality?
After Drag and drop an image file to 3ds max - an image plane with this texture should be created. With correct size.  Just add it as a 3rd option.
Come on, its simple as Finger snap, you could code it in 10 minutes.
Yes ... I know there are scripts
But again, its simple and and should be added as standard functionality..
2 Comments
mateusz_s
I mean this - just add a 3rd option here 🙂 it should take you 5 minutes 🙂
Thank you for the suggestion. Efficiency is important, and reducing the number of steps required to do this would be great.
