Direct file linking and conversion
okay so the description doesn't say much but it would be nice to have a button in every application that has a drop down that says
export to autocad
export to fusion
export to maya
export to 3d max
export to fusion
ect...
ect..
so that you can work on one project seamlessly and the program will AUTOMATICALLY add and recreate the new file with the appropriate data and extension file without loss of dimensional, surface or textual data... okay so I know this means a ton of data library building but it would be worth it.
or make it add to a library extension file that all programs can read and grab and filter the data seamlessly
(example  in Adobe I can create a photoshop file and its saved as a ps file I can go in and add it to a folder to an InDesign file where the part file will sit if I leave InDesign and change the photoshop file it'll automatically be changed and updated when I return to the InDesign file  seamlessly without having to convert the file to a jpg or to re-upload a new save file....  just an example but it helps with between department processes.)
oh yea one more thing
export to 3D printer...  ^_- that too
I work in  123D Design, 3ds Max, Maya, Autocad (least) inventor and learning 360 and app 360
1 Comment
Kelly_Michels
Status changed to: Archived
This is a bigger scope than the 3ds Max team and we do already have some of this in place with Send To workflows.  Also please see the link to Project Quantum https://architosh.com/2017/05/autodesk-explains-project-quantum-and-why-it-matters-in-aec
