default selected modifier
In the modifier stack we should be able to activate a button to toggle the default selected modifier.
When this button is active the default selected modifier should be the one at the bottom,
if it's off then it behaves as normal.
This is the general rule, that we should be able to overwrite by the exception and tell the modifier stack which should be the default modifier selected when you select an object.
This is extremely important for modeling,
since every time you select an object you have to click again in the editable poly level in the stack,
it would save hours of work on each model.
2 Comments
Kelly_Michels
brentscannell
Status changed to: Archived
