Currently, while Omniverse can open USD files with any root name (e.g., "Root"), its native convention is to use "World" as the root prim name. This can lead to inconsistencies or unexpected results when importing USD files exported from 3ds Max.
Proposal:
Update the USD Exporter to allow users to specify the root prim name manually for better compatibility with Omniverse.
Alternatively (or additionally), introduce a dropdown option to select the target platform, which would automatically set the appropriate root name based on the chosen platform (e.g., "World" for Omniverse).
Implementation Example:
local usdOptions = USDExporter.CreateOptions()
-- Set Gprim root name
usdOptions.RootPrimPath = "/" + txt_rootName.textThis would be a simple but impactful change to improve interoperability and user experience when working with Omniverse or other platforms with custom root names.
Fully Working Example:
try (
try (
cui.unregisterDialogBar SimpleUSDExportRollout
destroyDialog SimpleUSDExportRollout
) catch()
rollout SimpleUSDExportRollout "Simple USD Exporter" width:350 height:100
group "USD Export Settings" (
edittext txt_rootName "Prim Path:" text:"/World" fieldWidth:260 height:20
checkbox chk_exportSelected "Export Selected Objects Only" checked:false
button btn_export "Export USD" width:330 height:35 align:#center
on btn_export pressed do
-- Prompt for save location
local exportPath = getSaveFileName caption:"Save USD File" filename:"export.usd" types:"USD Files (*.usd)|*.usd|All Files (*.*)|*.*|"
if exportPath == undefined then
messageBox "Export cancelled!" title:"Export" beep:true
return false
try (
-- Create the USD export options
-- Set Prim path
usdOptions.RootPrimPath = txt_rootName.text
-- Basic options (setting reasonable defaults)
usdOptions.FileFormat = #binary
usdOptions.UpAxis = #y
usdOptions.Meshes = true
usdOptions.TimeMode = #current
-- Perform the export based on export scope selection
local exportSelected = chk_exportSelected.checked
if exportSelected then
if selection.count == 0 then
messageBox "No objects selected for export!" title:"Warning" beep:true
return false
-- Export selected objects
USDExporter.ExportFile exportPath exportOptions:usdOptions contentSource:#selected
else
-- Create a node list of all objects in the scene
local allNodes = for obj in objects collect obj
-- Export all objects as a node list
USDExporter.ExportFile exportPath exportOptions:usdOptions contentSource:#nodeList nodeList:allNodes
messageBox "USD export completed successfully!" title:"Export Complete"
) catch (
messageBox ("Export failed: " + (getCurrentException())) title:"Error" beep:true
-- Create the dialog
createDialog SimpleUSDExportRollout 350 120 style:#(#style_titlebar, #style_sysmenu, #style_border)
) catch (
messageBox ("Error: " + (getCurrentException())) title:"Script Error" beep:true
