Ctrl+ Rotate rotates object 45 degrees
Ctrl+ Rotate rotates object 45 degrees.
2 Comments
brentscannell
Hi @ViperAleks
Are you already using angle snap toggle?
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/3DSMa...
Depending on if you need to maintain two different sets of increment values or not, you could achieve what you're looking for by right clicking the icon and setting the rotation increment to 45 degrees. Once set, you can toggle the angle snap on and off using the default shortcut "A"
ViperAleks
I use snap tool but I use default 5 degrees value.
