Compact Material Editor - Multi/Sub-Object is limited to 10
there is only 10 sub material slots visible.
Have to use a slider if more sub materials are used.
How great it would be if I could use all my monitor vertical resolution to see the submaterials...
1 Comment
dswahn
Yes please.
Also, admins please merge votes and suggestion with previous (same) suggestion: https://forums.autodesk.com/t5/3ds-max-ideas/set-height-of-multi-sub-list-in-material-editor/idi-p/...
This simple change needs to be addressed since it's long overdue.
