Chamfer Flow Loop Inset, Relative or Proportional Amount Option
flow-loop.PNGoverlapping on the inside, because the inset amount is too bigoverlapping on the inside, because the inset amount is too bigI just hope for a solution that will make the flow loop inset option variable, we already have an option of chamfer by weight. Maybe we can have varying flow loop sizes that is relative or proportional on how big the chamfer is. Also a revamped "limit effect" to avoid chamfer overlapping.
1 Comment
can you describe this suggestion a bit better !
