camera shortcuts : keyboard shortcuts to cycle forward and backward through all existing cameras
Please add keyboard shortcuts to cycle forward and backward through all existing cameras in a scene. This would eliminate the need to go through the outdated and cumbersome menus, which currently require multiple clicks to access each camera. It would be a huge time saver for users and, in my opinion, relatively simple to implement.
Additionally, I suggest improving the current camera and light selection menu system. When there are more than 10 cameras, the interface switches to a two-level nested menu, which is inefficient and slows down workflow. Replacing this with a single, unified selection system would provide an immediate sense of ergonomic improvement for all users.
3 Comments
miauuuu
Here are two scripts to do what you need: miauu's CameraCycler
pastorpastor
Thank you to both of you for your scripts links , I’ll get check this out  !
but I still think those shortcuts fonctions should be provided by default and the menu with maximum 10 cameras should be revamped in future release .
thanks .
