Built-in output player Please ..!!
3ds max support rendering of stills and animation, speaking of animation output we syll have to rzfer to the file (avi) to play and preview out render animation.
We need more than this, that is a built-in animation (3ds max player) where we play animation inside 3ds max directly after rendering without going back
to file explorer and running the avi file.
moreover this 3dsmax player can serve as animation previewer that is we can play those already rendered frames while we render the rest. instead of interrupting the whole animation rendering process.
NB,Hicham
5 Comments
RGhost77
Kelly_Michels
pyroskat
Thats totally needed!
JohnnyRandom
RamPlayer is ancient single threaded code that takes a long time to load short 2k sequences let alone 4k, not even to mention simple layer composites are impossible.
Tweak RV would be a solid and suitable replacement that is agnostic of its host package and Autodesk already owns it.
Of course a from the ground up built in multi-channel multi-threaded flipbook player is fine to, regardless something needs to happen.
LOMBARDIAUGUSTO
id like to have the option to save out a mp4 or avi to share with clients or for review in general
that would be a valid add on to ram player
