Good time of day. I've known 3ds max for a long time. If you want to make a top product for people. Then invite me as a consultant, on a permanent basis to your staff. Second, fix the bugs with the Boolean operation. It is not possible to work, does not cut properly. If it cuts the grid, then you need to create a polygon one from scratch . And so you can talk about shortcomings. Many hours. Just contact the staff for half a year. And your product will Shine in the rays of glory. Plus add smelting which will be better than in zbrash. And once again, it is impossible to work with the model after Boolean operations with the text and the smoothing modifier. Plus, there are many more different ideas.
