Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Better XREF - ability to adjust presets AFTER importing xref objects
When you have loaded a file with XREF objects, and forgot to set the right presets regarding how to handle tracks and modifiers, you are not able to change the presets.
It's very frustrating, if you've set up a scene using a ton of xref objects, and then find out, you had to use the "local" for tracks, and then you can't change the "import" settings. I did a workaround by changing the controllers of all the xref objects to "PRS", instead of XREF manually afterwards, but each time I create new objects in the xref object file, and update, then their controllers also have to be changed.
Why can't you just change the "import" presets later on, if you want to?
Well - now you can - if you vote for this "so called idea" (not a thing that was obviously missing in my opinion)
Best, Jesper Colding
Denmark
Denmark
