Allow us to hot-key "Use X Center" for transforms.
Set or toggle the different transform centers for move rotate scale with hotkeys/quads etc.
Seem like there are scripts you can run for this but it really just need to be simple to set up and saved in a hotkey file so we don't have to mess with it every update.
https://forums.autodesk.com/t5/3ds-max-forum/use-pivot-point-shortcuts/m-p/4171263#M52304
https://forums.cgsociety.org/t/hotkey-use-pivot-point-selection-and-transform-coordinate-center/1810...
4 Comments
teratron
Never mind, the answer is "Center Point Cycle".
so can you cycle thought them with a shortcut ?
teratron
@Kranos_Orphydian  Yup! Just hit that with the desired hot key.
so I guess this should be deleted or archived
