Allow group of materials labels in Slate Editor
This is quite standard in node editors, specially material-shader editor but not present in the Slate Editor.
It would allow group under a label several materials or maps in order to be able to understand the content. Eventually with many nodes Slate becomes unreadable without this.
6 Comments
It would be very beneficial to alot of users if we had any control over the organisation of materials in the SME. Because currently we have basically nothing. The tab system is ok but it just makes it harder to find things.
Max should adopt the standard pretty much everyone seems to have adopted which is to allow groups of nodes like in substance, nuke, unreal etc as seen in the image attached.
Im quite tired of having to search my editor for a material so being able to label the groups or add notes within the SME should also be considered.
rasmus.selker
This was requested early after the introduction of the slate editor... It's hard to believe it has not been implemented yet!
definitely
Grouping Nodes In Slate Material Editor
is this old idea a similar thing ? if so maybe merge them too
shawnolson
Status changed to: Accepted
shawnolson
