If I make a helper using a mesh object and name it DUMMY_something, your system should automatically make it non-rendarable because it detected the word DUMMY.
Or if I go a long way to get to where I want to be many times (Menu, for example), but there is a shortcut, your system should detect this pattern and tell me that there is a short cut for it. (Auto preview a shortcut name to the side. Eventually we will remember it. Let's I always go FILE>SAVE auto preview after 10 times a message: "You can also use CTRL+S to save" )
Or if I model/animate it the wrong way, like going through extra unnecessary things, your system should learn my habits and advise a better way to do it.
Or auto-naming based on a model shape, auto search PC for missing textures because a new hard-drive letter was change. You still have an issue with it.
You can add AI weights how aggressive AI is with suggesting, auto changing settings for a user, correcting user's habits.
Simulations settings should be also auto previewed in real time VISUALLY using AI so i don't have to change one number and restimulate and waste my time,
etc.
