Add gLTF support, export and import
gLTF is quickly gaining momentum, many online and offline engines support this interchange format. Autodesk itself is supporter of the gLTF standard. Let's add native gLTF import and export support to 3dsMax!
65 Comments
this
Smallpoly
Yes, that.
brentscannell
yes please !
Any update on this? 'Future consideration' sounds still very far away.
I am pretty sure gltf/glb has a huge potential and it's definitely something we don't want to miss in the future.
Blender is having a very active community and it looks like it is/will be integrated by default for version 2.80:
https://github.com/KhronosGroup/glTF-Blender-IO
Also Babylon.js is making very good progress on the gltf/glb exporter for 3ds max:
https://doc.babylonjs.com/resources/3dsmax_to_gltf
Maybe you could get in contact with the guys from Babylon.js.
Looking forward to your update!
Yes please, lot's of big companies are starting to use glTF now! It would be great if we can complete the circle and are able to import glTF files back into max. We're now forced to switch to tools such as Blender to import these models.
klaasnienhuis
Some interesting links regarding gltf and file conversion:
An fbx to gltf converter: https://github.com/facebookincubator/FBX2glTF
An obj to gltf converter: https://github.com/AnalyticalGraphicsInc/obj2gltf
ClayGL is a webgl viewer and also converter: https://github.com/pissang/clay-viewer#converter
Babylon.js, besides being a webgl framework it also has an exporter for 3dsMax to create webgl files: https://github.com/BabylonJS/Exporters/tree/master/3ds%20Max
yes.. we need gLTF import and export options. Heart
alex
Verge3D for 3ds Max comes with the full-featured glTF exporter plug-in. See this video overview on the ADN channel.
mhj.notenboom
Currently I cannot import a gLTF downloaded from SketchFab into 3DS MAX
Guido
Important. Although The Babylon Exporter is already a good plugin but as this will mainly become an industry standard, it should be correctly implemented natively by the Autodesk Team
mail
IMPORT to 3ds Max option, please...
jeff.zehner
Import/Export should be standard part of Max
Another customer vote here for native import and export of gLTF. Original post is coming up on 3 years old. Any update? Thank you!
autodesk
Observer
There is a serious need for this.
Tvortsa
Autodesk, week up! Are you sleep !?!?!?!?!
Any reactions? no ?
brentscannell
Hi all,
I'm sorry that you haven't seen much traction on this idea here. I've neglected to keep this one fresh and up to date.
Last year, Autodesk formally joined the Khronos group as a contributor member. Since then, representatives from various product teams have joined in the regular development meetings for some different initiatives: 3D Commerce, which aims to standardize workflows and visualization of 3D Content in an e-commerce context, and 3D Formats, which is developing glTF.
We are keeping a very close eye these standards, and even contributing to the development in some cases. While I know that for most of you, all this boils down to just being able to export a glTF directly from 3ds Max, I ask that you trust that we are finding the best strategic fit and form, while aligning some development activities. We are researching an exporter, but I can't comment on the potential timeline for delivery just yet.
For those interested in discussing your needs around this topic more directly, please reach out via direct message or email, or keep the comments rolling in this thread. We are actively looking for customer stakeholders to help steer this effort.
echadwick-artist
I found a hacky way to import glTF into 3ds Max, using Open Asset Import Library https://github.com/assimp.
  1. assimp export myfile.glb -ffbx \\converts a glb into a fbx model.
  2. assimp extract myfile.glb \\extracts textures from a glb, in their native format (jpg or png).
  3. Import the FBX.
  4. Make a new Physical Material, and hook up the textures.
It's important to note however that glTF is a lossy format. It's not a good format for translation of source assets because you lose fidelity, often significantly.
Still, it is useful to use 3ds Max to examine the layout of an exported model, and identify the ingredients/textures/UVs/etc.
Extremely important feature; currently our team needs to use multiple tools (FBX2GLTF, Blender, Babylon exporter + online viewer) in conjunction with 3DsMax to be able to author assets in our preferred DCC (Max) and convert, validate, and view the GLTF/GLB asset.
alex
Why so complicated? Verge3D offers direct export from Max to glTF 2.0 and also supports Max' native materials, maps and lighting.
