XForm Modifier Bug
XForm Modifier Bug
Grace.Tevlin
XForm Modifier Bug
Grace.Tevlin
3dsmax 2023 XForm Modifier has a bug.
Renaming the modifier and ON/OFF Toggle get reset after saving and reopening the project.
Any idea how to fix this!?
Grace.Tevlin
This issue started from the first Max 2023 release. It was reported to Autodesk support without any solutions.
It has been tested on few machines and all the same.
Tested on a fresh Max 2023, also another one with VRay plugin installed.
A sample project with a video is attached.
Diffus3d
You might want to file a support case for this one at Manage.autodesk.com, this isn't something someone here can likely help much with.  Strange one indeed.
Best Regards,
Grace.Tevlin
We did that twice months ago and they filed the issue, but still nothing after two updates released from Autodesk.
mhj.notenboom
We have experienced the same and it is a nasty bug. We cannot trust our work anymore when we use Xform. Only way is through script by elimination the whole modifier stack and recreating. When opening the file later all Xforms that were hidden are back on and all names are lost.
This is a major bug!
Grace.Tevlin
It is so ANNOYING and no solutions from Autodesk!!! We decided to switch back to Max 2022.
