Wrong XYZ values in measure box.
emre.aksu.78
Observer Observer
emre.aksu.78
Observer
Observer
Hi everyone. I type 35 in the box but it shows a different value (34,999992). How can I fix this problem?
raiden_xavier
Hi @emre.aksu.78,
Thanks for sharing your issue with us.
Sorry to learn you are experiencing this.
If i see correctly that is a comma in the number field? What is your OS language?
I think issues can occur in 3ds Max when it comes to comma and period.
Could you try the following?
Change the Windows OS keyboard and Language to English (US).
Test.
(Then back to your native setting if you do not use ENG settings as default)
We look forward to hearing from you.
Many thanks.
darawork
Hi another thing to try would be to move the object closer to 0,0,0 if it's not already located there. The read out in the transform boxes might be actually be correct; if your model is really far away from 0,0,0 then some slight measurement inaccuracies may occur.
https://forums.autodesk.com/t5/3ds-max-forum/viewport-accuracy-issues/td-p/10271204
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
