3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Wrong FPS Rendering
6 REPLIES 6
1052 Views, 6 Replies
Wrong FPS Rendering
I have a big issue with FPS.
In the Time Configuration Panel, my frame rate is set to 30 fps (NTSC) i worked on my scene with this frame rate without changing it.
I animated a ball moving sync with the music i set on track bar (Mini Curve editor, etc.)
Then i simulated the smoke animation with FumeFX and when i render the animation (Scanline), AE tells me it's 25 fps.
Which doesn't match with music anymore... 😞
Now i try to change the FPS in Time Config Panel, and when i exit the panel by clicking on "ok" parameters don't change.
I don't know what's wrong with it but if i can't fix this, i'm going to get crazy (i animated 2500 frames 1 by 1...)
Help me !
6 REPLIES 6
surely you can interpret an image sequence however you want in AE.....simple search on the net:
AE change fps
answer right there..
(when you say: AE tells you it's 25 FPS...that might just be the current default.....so change it)
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I agree with @Anonymous, you just need to go into the project or composition settings and change the framerate to 30fps in AE.  Did this work out for you?
Best Regards,
in reply to: Alfred.DeFlaminis
Yeah sorry i didn't take time to reply but yeah it worked, i got the solution right after posting here, by a friend who got the same problem [😊]
Thanks guys !
Alfred.DeFlaminis
Thanks for the update and confirmation @Anonymous, I appreciate it!  Glad it's working for you now and hope it comes out great.  Smiley Very Happy
Best Regards,
ddarq17
Whats the solution, i have the same problem? Help pleaseeeee
ddarq17
