hi, need help to setup wireless network rendering, is it possible - 3ds max 2018. thank you.
Hi Bgersak,
Thanks for your question.
In general, you should be able to do network rendering over wi-fi without any issues, as long as the render nodes on your network are accessible and recognized by your Manager machine. The biggest caveat would be overall job submission speed -- for instance, if you were submitting a job via Backburner, with "Include Maps," and the job was quite large, it will take more time to transmit via wireless than if all your render nodes were wired directly into a hub or router via Ethernet cables. However, I ran several network rendering machines via wifi (each with their own wireless dongles attached), network discovery enabled and Windows Remote Desktop to access each, and didn't have many issues.
Finally, if you're looking for alternatives to Backburner, please look at the information in this article. Thanks!
