I drew a window on the wall with the window command, but even though it is drawn on the wall, no space is formed and is not visible.
Solved by leeminardi. Go to Solution.
Check out this video (not sure if Autodesk is still supporting Screencasts). Set snaps as noted in the video and remember to do CLICK, CLICK, DRAG, CLICK for the start and end of the window width, the drag is for the window depth and the last click for the window height.
hello i found a method. The problem is solved with the select and link command, but I couldn't apply the select and link command in the 2023 version. Only luckily it happened in one
