3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
wierd white shadows affecting alpha pass with VRAY
1 REPLY 1
Hwagner
1240 Views, 1 Reply
i am rendering this view, the gras seems to be casting a weird white shadow. i chech the alpha and it is affecting it aswell. WTF is going on here? i have never seen this before and cant seem to find an answer. there is a plane under the grass and a curb right against it, there is no reason for this issue. i hope someone can answer this for me. pulling a late night trying to get this finished.
max 2016
vray 3.60.04
forest pro 6.1.1
unkempt grass preset that comes with forest pro
1 REPLY 1
Hwagner
in reply to: Hwagner
well. i found a solution, i increased teansparency samples in the global switches and the issue went away. something so simple and hours lost.
i guess it is an itoosoft plugin issue. the solution is to reduce the distribution size in forest pro, which isnt really a solution, especially when using the edge cleanup mode,  or increase transparency samples in the global vray switches.
