Wierd problem with user interface.
This problem is very annoying,for some reason I can't close the render setting box,I can't even scroll the render setting box.This also happened with the material editor box.
Also one more problem  that happens along with this is that I can't select any of the tabs in the enuy like file,edit,tools,group,view,modifier ect.
miledrizk
I think you should reset your user settings:
1- Close 3DS Max
2- Go to: C:\Users\YourUserName\AppData\Local\Autodesk\3dsMax\20xx - xxbit
3- Rename the folder called ENU to something else like ENU.Old
4- Restart 3DS Max
Note: AppData is a hidden folder so you need to enable show hidden folders from the Control Panel
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
