Which node does the diffuse texture go into for a Physical material?
Capture.PNGSelf explanatory. I can tell which one is for Roughness, Metalness, Bump, etc...but I can't find the one for the diffuse/albedo texture, and "Base Color Map" does not seem to be the correct one.
Can someone help?
Daf
Base Color Map is the correct node. Why do you think it's not correct? Where are you exporting your maps from?
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Hello, sorry for the late reply. Apparently I was doing it correctly and didn't realize because I wasn't looking closely enough.
However, the mesh that uses the material still appears all white in the viewport, and I want to fix that.viewport.PNG
Daf
Make sure that you have the Show Shaded Material in Viewport enabled. It's an icon/button on the toolbar in the Material Editor. And that you have assigned the material to the mesh.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/3DSMa...
3DS Max 2020.3
