3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Where is my gimbal
6 REPLIES 6
2025 Views, 6 Replies
Where is my gimbal
I tried to solve a problem the other day and made myself a new one. What else is new? I have attached a picture for you. I have checked costumize, preferances and gimbal, and I tried ctrl+shift+X, it all looks right. I tried googling for transform gimbal, but can't seem to find the solution.
So here I am making a fool out of myself, asking you this most likely silly question 😞
I have the student version of 2018, as you can see in the picture. I find it a bit difficult to move my plane into position without the arrows.
6 REPLIES 6
miledrizk
Well I'm just guessing and I think there are that two things you need to check:
1- Click the + sign on the keyboard repeatedly to make the axis bigger, maybe you clicked
The - sign many times by mistake.
2- Another possibility is that the pivot point, for some reason, is shifted away from the object,
So go to the Hierarchy panel, click the button labeled Affect Pivot Only, then click the Reset Pivot,
Or Center To Object
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
kgokhangurbuz
Hello @Anonymous;
Can you please check if your transform Gizmo's are on or off and their size for me? here's how:
-Go to Customize > Preferences > Gizmos
-At the very top - left, you'll see Transform Gizmos "On" button. You'll also find the "size" parameter at top - right.
Default Size value should be 30'ish.
If everything's fine here, what @miledrizk mentioned about pivot point might be the issue.
Keep me updated please.
Kind regards;
Thank you for your suggestions. I'm updating my computer with a better fan, more ram and storage. I will check this out when it's up again.
in reply to: miledrizk
I have tried all your solutions, and it's no change I'm afraid. I have attached the screens from preferences and pivot point screen.
miledrizk
This is strange! but anyway try this:
1- Close 3DS Max
2- Go to: C:\Users\yourusername\AppData\Local\Autodesk\3dsMax\20xx - xxbit
3- Rename the folder called ENU to something else like ENU.old
4- Restart Max
Note: AppData is a hidden folder, so you need to enable show hidden files and
Folders from the Control Panel
miledrizk@gmail.com
Thank you, that fixed it. Except for all the things I have to arrange, but the gizmo is more important, and it was about time with a cleanup. so Thanks.
Technology Administrators
