When i open a file with an osl hdri map. I get these errors. what's the reason?
The corresponding OSL map cannot be used and can only be used if a new osl hdri map is created.
Why? (The corresponding osl map was created in 2021, loaded in 2022)
Solved by CiroCardoso3v. Go to Solution.
And what happens if you load the HDRI with the OSL HDRI from Max 2022? And does it happen with all the OSL nodes?
When I reload it, it works fine.
But reloading all hdri nodes in many of my scenes was cumbersome
